07-15-2022
18:38
09:24
DavideFitbit
07-15-2022
18:38
09:24
DavideFitbit
My Charge 5 will Charge but after about 2 hours the battery is low at 5%. I can't really use it for anything. There are no outstanding updates. How do we fix this?
Moderator edit: format
Best Answer07-16-2022 09:23
07-16-2022 09:23
Hi, welcome back to the Community forums, @Karen.O.
Thank you for all the information that you've shared about this inconvenience with your Charge 5.
Battery life can vary depending on how often you use some of the features available with the device, but it should be lasting for only 2 hours. Letm know if you're using the GPS, as this is often one of the features that makes the battery drain faster. Before considering other options, please make sure that you've followed the steps provided in this article to improve battery life in general.
In addition, the team is aware of a battery drain issue affecting some Charge 5 devices in which the built-in GPS chip may remain active after ending a GPS-enabled exercise and they've working on an update to fix the issue. In the meantime, it is recommended to try a three pulse restart. Please note the following:
I'll be around.
Best Answer07-18-2022 07:59
07-18-2022 07:59
07-25-2022 10:40 - edited 07-25-2022 10:41
I have communicated with three different customer service reps in this regard over the past few days. I've disabled ALL of the things that allegedly were causing battery power to lower. It worked just fine until Saturday, 7/23. I have insurance, have had the device for less than six months, and a premium app membership. The device just not working and waiting for some change isn't enough. "Make sure to keep your app and device updated" is not help when the device dies the moment you unplug it from the charger. What is the company going to do about this?
07-25-2022 10:52
07-25-2022 10:52
Best Answer07-25-2022 11:04
07-25-2022 11:04
Unfortunately i now have the same issue. I brought my charge 5 in Dec-21 and have been using it successfully up until last week with all functions including GPS enabled. The battery would last up to 5 days with most features enabled and heavy usage with walks, cycle ride and general exercise. Last week it started draining in the space of 2 hours. Fully charge after a reboot and within 2 hours drained. I've been through support who gave me the usual switch everything of link as GPS will drain the battery. I was told a replacement would be sent but their systems were down so expect an email. No email arrived, contact support again and they told me I would have to wait for technical support to determine the cause, something i believed they had already done. I see there is an update for battery drain issues, but don't get why it's been fine for nearly 8 months and now suddenly doesn't work. Very odd.
07-25-2022 12:22
07-25-2022 12:22
I am having the same problem with my Fitbit charge 2 . Thanks
Best Answer07-30-2022 12:41
07-30-2022 12:41
Hi everyone, thank you for all your replies and for sharing these updates.
In addition to all the steps mentioned earlier, keep in mind that a new firmware version was released recently and this should address the problem with the battery of Charge 5 that is draining too fast. You should be receiving the update soon as well and you can find more instructions in this article on how to complete it.
If you already tried all the step mentioned earlier and you continue to have the same problem after the update, I do recommend that you continue the communication with the Customer Support team so they can provide you with the next steps.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
See you around.
Best Answer07-30-2022 14:11
07-30-2022 14:11
Best Answer08-03-2022 09:41 - edited 08-03-2022 09:41
Im pleased to say Google have sent a replacement Charge 5, let's hope this one lasts a bit longer.
