My Charge 5's ECG functionality has stopped. It seems to be the side sensor reading issue, although the EDA Scan works. I did a hard reset; removed and reloaded the ECG app; and talked with Fitbit. Fitbit gave me a case number but no reason for ECG problem, and no follow up. Any suggestions to remedy problem. My Charge 5 is 1 1/2 years old. Thank you.
Hi, it's good to see you visiting the Community forums for the first time, @HMR60.
Thanks for confirming that you already tried a few troubleshooting steps.
Could you please confirm if by any change you've travelled to a different country? This feature is restricted by location and it may be deactivated when traveling to a different country where it's not currently available.
I've been informed that you have indeed contacted the Customer Support team for further assistance with this and it seems they've shared some instructions with you. In this case, I recommend that you continue the communication with them and they will let you know how to proceed.
Have a good day.
Best AnswerThank you for responding. I have not heard anything from Fitbit. I am located in USA, but was on a cruise in Eastern Caribbean in December. Otherwise no international travel. But wouldn't a reset help that, if there was a problem from travel?
@HMR60 Thank you for your reply.
It seems that you were able to get in touch with the Customer Support team and they've provided you with some instructions. If you don't see their reply, please make sure to check on your spam folder as well.
@Yaya08 If you haven't done so already, please make sure to try the following steps as well:
