06-05-2023
09:30
06:52
06-05-2023
09:30
06:52
My fitbit got emptied out of power, but now I can't get it to get any power back at it at all. And the apps says that's it can not sync either.. That's weired not as it will not get on after I emptied the power out! My charger will not give it power.. It turned on a few times then all black again.. With even less power..
Moderator edit: clarified subject.
06-05-2023 13:12
06-05-2023 13:12
Have same problem
06-05-2023 13:39
06-05-2023 13:39
Hi & welcome @MissSPG and @huijiexin ,
Sorry to hear that you are both having issues with your devices.
The first troubleshooting tip to try is restarting your device using the charging cable that came with your Fitbit. Click here to get more detailed instructions on Restarting the Charge 5
Hopefully, performing a restart will fix both the charging & synch issues.
06-06-2023 05:55
06-06-2023 05:55
Plz tell me how to restart a product that don't wanna get power back on to it. After this have been done...
06-06-2023 06:56
06-06-2023 06:56
Hello there, @MissSPG. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Charge 5. @RiekoC Thank you so much for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance. I hope we can solve your issue soon!
@huijiexin It's nice to see you around! If you haven't done so yet, please follow the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
06-06-2023
07:17
06:14
DavideFitbit
06-06-2023
07:17
06:14
DavideFitbit
Yes I contacted the support team as I'm haven't had this problem on this charge 5 before it turned out off power. Before the program update that was last time I didn't have this issue at all.. So I'm wondering if there is still any way around this to get it to receive any power at all.. Because with this button on the charger there has to be something else that can restart this prosess.. I've tried everything about 3 x times before 8 seconds runs out.. But this don't Looks like it will do the trick.. So I'm trying to figure out how to make this work with any another amount of pulling that button.. Sorry my bad English..
I gave up! Getting a new one from the support team..
My warranty was valid that's why I get a new one...
