I've been trying to look up solutions and haven't found one yet. My heart rate sensor on my Charge 5 is not functioning (green light isn't coming on and no data shows on watch). I've tried restarting the watch and I've checked the settings on the watch (it is turned on). Anything else to try? Thanks.
09-23-2022
07:17
15:53
09-23-2022
07:17
15:53
Hi, thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5 and that you already tried a few troubleshooting steps, @LastCenturion.
Before considering other options, let me know if the restart procedure you tried is the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, this has been useful to other users who have experienced something similar.
I'll be around.
Best AnswerGood day,
Sorry it has taken a while to respond, life is hectic. The update is that it still is very periodic on when the heart rate monitor works, that is, very infrequently (or maybe I don't have a pulse).
Further issue (not sure if related or not) is that the battery won't hold a charge. I have it die on me about every other day.
What can be done to get this working better? I've only had this tracker since around February of this year.
Thanks.
12-31-2022
09:27
08:46
12-31-2022
09:27
08:46
@LastCenturion Thanks for confirming that you already tried all the steps suggested earlier and that you continue to have the same problem. .
In this case, I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon.
See you around in the Community.
