The reminders are set for every day, 9AM-6PM in the app. Reminders are on.
I get vibration notifications from text messages on my Android phone.
I've done a soft reboot of the device, scrolling up from the main screen.
What am I missing?
Thanks in advance.
Hi @DannyS. Welcome to the community forums.
Thank you for providing the details regarding the situation that you are experiencing with reminders to move.
Do Not Disturb Mode or the Sleep Mode (Quiet Modes) could be turned on in your quick settings, since both of these options prevent the device from receiving notifications, reminders to move or celebrations. If you haven't done so already, please make sure these feature are disabled in your settings.
Please perform the restart procedure with the three pulse using the charging cable. In addition, please try setting up the Charge 5 as a new device in your account if you're still having the same problem. Then repeat the restart procedure and set up notifications to check if they're working properly.
Best AnswerThank you for your response. Unfortunately it didn't work.
I deleted all info from the device and removed from the app.
I can't use the "3 pulse" method mentioned as there is no button anywhere on the charging cable.
Any thoughts?
Best AnswerHello @DannyS
There is a small inset button on the USB end of the charging cable that came with your Charge 5. See picture below.
What I've done when my Reminders to move aren't triggering is:
Hopefully, this process will work for you.
I saw that you've tried doing a factory reset (remove user data), which didn't work.
One more thing that you can try is:
