10-09-2021 16:39
10-09-2021 16:39
I'm on my 5th new fitbit--now just got Charge 5 and always there were prettier bands, adjustable metal made by various companies also. After google took over we are stuck with these rubber infinity bands that are miserable to fight daily after showering. I bought the ones that have holes in them but again your rubber cheap looking band....Whats up with that??? Is this going to be fit bits new agenda for bands because if that be the case I'll switch to apple and get a watch where I can get lot's of other bands that fit bitter and are better selection I have a very small wrist so yes it's a big deal for me. My husband hates the band as well, the notch come undone when trying to put under the band and we live in Arizona when you sweat more so this band is rotten to the core for us.
05-29-2022 23:10
05-29-2022 23:10
Best Answer10-09-2021 17:04
10-09-2021 17:04
Plenty on Amazon to choose from.
Best Answer10-09-2021 17:09
10-09-2021 17:09
10-09-2021 18:20
10-09-2021 18:20
I just looked and found some.
Like any new product, it may take a few weeks for third party accessories.
Best Answer10-09-2021 18:55
10-09-2021 18:55
Well-I look and see nothing for charge 5 that is not rubber. Perhaps you would share where and whom makes it as none on amazon nor on web for what I want.Want a stainless steel womens adjustable band, fit link has for charge 3 and 4 but 5 is a totally different connection so manufacturers must make new design to work on Charge 5. Please share where it is as I'd truly appreciate finding NON cheap rubber bands.👀👀
10-09-2021 20:01
10-09-2021 20:01
I don't know where you're based, but I think they'll turn up very soon. There is something on the Amazon Japan site and I'm guessing other countries will see them in the next day or so.
Hopefully your patience will be rewarded very soon! Hang on in there.
10-11-2021 09:39
10-11-2021 09:39
Agreed. More options are needed on the bands.
Best Answer05-29-2022 15:06
05-29-2022 15:06
I have to agree with you there.
Best Answer05-29-2022 23:10
05-29-2022 23:10
There are plenty https://www.amazon.com/s?k=charge+5+bands
