08-25-2023
10:07
11:52
08-25-2023
10:07
11:52
Charge 5 recently started to last only for a day after lasting a week. No changes have been made
GPS is not used, screen is not turned on often. I have gone through the troubleshooter steps.
Device has been rebooted. Firmware is up to date. Can anything else be done?
08-25-2023 11:48
08-25-2023 11:48
Hi @imlitimlit sometimes batteries die over time. You seemed to have done everything possible. You get with customer support?
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or X/Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
08-25-2023 12:51
08-25-2023 12:51
Hello & welcome @imlitimlit
When my Charge 5 battery started dropping power rapidly, I restarted and recharged my device multiple times over several days. This process eventually got my Charge 5 "unstuck" and the battery went back to lasting 6-7 days.
A couple of users found that turning off SpO2 helped reduce battery drain. One of the users also un-installed ECG & EDA, which also helped reduce battery drain. This user's post has several troubleshooting steps that they did with some success: Possible fix for rapid battery drain
Hopefully, these suggestions might work for you.
08-25-2023 15:00
08-25-2023 15:00
Don’t let Fitbit lie to you. It’s happening to everyone. Go see the other forums. Fitbit has scammed everyone. They ruined everyone’s device and making us buy new ones.
08-25-2023 16:34
08-25-2023 16:34
I’ve had several Fitbit over the past few years. If they don’t warrantee this Charge 5 it will definitely be my last Fitbit!
08-26-2023 01:46
08-26-2023 01:46
For the second time my Charge 5 died!
Happen one year ago about, battery drain in 1-2 hours. Fitbit changed it.
Yesterday suddenly my charge5 died again, all light off and not turn on. If I connect charger I have vibration feedback but no light on and no display on.
Support changes again my device 😞 They are always kind and helpful.
I hope charge 6 solves this else I'm forced to change my brand 😞
08-31-2023 07:09
08-31-2023 07:09
Now it has failed to charge at all. Dead Dead Dead after almost two years.
I was offered a small discount on a new charge within 30days from their store. That kinda sucks.
Not going to get another.
