11-27-2023
03:51
05:47
11-27-2023
03:51
05:47
Charge 5 battery drain in less than two hours. I stop using it for about three months and started it again today. no change. Still the same
Best Answer11-27-2023 05:49
11-27-2023 05:49
Hi there, @NareshSathy. Thanks for stopping by in the Fitbit Community Forums. I'm sorry to hear that the battery of your Charge 5 is draining quickly. I understand where your concern is coming from. I'll do my best to help you with this.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please complete a three pulse restart following the steps listed here below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
Hope that helps.
Best Answer11-27-2023 05:51
11-27-2023 05:51
I have done this many times
Best Answer11-30-2023 11:13
11-30-2023 11:13
It has happened to my Charge 5 also, my Fitbit has been ok, then over the last week it has started draining the battery really quickly, now I have to charge every 4 hours or so, how do I know if my Charge is still in Warrenty,
