03-15-2024
00:35
07:27
03-15-2024
00:35
07:27
Don't understand why my Fitbit battery is draining within 3 days.
Any one facing similar problems?
Any solution
Best Answer03-15-2024 07:32 - edited 03-15-2024 07:32
Hi there, @Bindhu271 @Conka. Welcome to the Fitbit Community Forums. I'm sorry to hear that the battery of your Charge 5 devices are draining quickly. I understand where your concern is coming from. I will do my best to help you with this!
As a first approach, I'd recommend to follow the recommendations listed in this article to improve or extend battery life. There are a few features that would make the battery drain faster than usual, even in one day. Some of these features are:
If this doesn't apply to you, another step that has been helpful for other users having battery draining problems is the three pulse restart procedure using the charging cable. Nevertheless, since you mentioned you already tried that, please confirm that you performed the restart as described below:
Best Answer03-15-2024 00:57
03-15-2024 00:57
Mine is reducing to less than 24 hours
03-15-2024 01:01
03-15-2024 01:01
Hope someone can post a solution.
I have had this problem with earlier models
Best Answer03-16-2024 11:33
03-16-2024 11:33
Hello @Bindhu271 & @Conka
When my Charge 5 battery began to rapidly drop in power, I restarted & recharged my device multiple times over several days. This eventually got my Charge 5 "unstuck" and the battery went back to lasting 6-7 days. Although there's no guarantee that this will work for you, it might be worth a try.
Best Answer03-16-2024 11:37
03-16-2024 11:37
Best Answer03-16-2024 12:39
03-16-2024 12:39
I called and they had me change gps now to phone bs dynamic and it’s helped. I only use gps to track walks so just am sure location is on iPhone anyway. However, now my sleep is not syncing. Turned Bluetooth and phone on and off but not helped. Try your gps setting and good luck.
Best Answer03-18-2024 08:11
03-18-2024 08:11
Thank you for sharing!
Will try that for whatever it's worth
