03-08-2023
06:52
03:52
03-08-2023
06:52
03:52
I have had my charge 5 for a year now, it worked flawlessly until about a week ago. I charge I to 100% and now it won't even last 4 hours. I've restarted, and cleared data. The one thing I haven't done is a software update. Go in to do that but it's not showing up. What can I do to fix this?
Best Answer03-09-2023 04:03 - edited 06-03-2023 11:28
Hi there, @LeePittman. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Charge 5 before reaching out.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please confirm that you've restarted your Charge 5 as described below:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
Best Answer03-09-2023 06:38
03-09-2023 06:38
Everything you just talked about did not work. I have to charge it every four hours now, why even have this thing, it's useless to me. As far as I'm concerned this was a waste of money.
Best Answer03-13-2023 17:50
03-13-2023 17:50
No because I've tried everything you mentioned and still only get a four hour run time. Then charge it for two hours. Then wear it for 4 more hours. Kind of stupid you think. Me what's the point of wearing it. So what did you want me to do? Can I get a new one?
