Charge 5 battery is draining quickly
ANSWERED
My charge 5 won’t hold a charge more than 8 hrs. Any suggestions??
1 BEST ANSWER
Accepted Solutions
Hi there, @Ldk46. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. @DramaQueenDiva Thanks for moving the post.
If you haven't done so already, please make sure that you've followed the steps provided in this article to improve battery life in general, as this has been generally useful for other users. In addition, please confirm that you've restarted your Charge 5 as described below:
  1. Connect your device to the charging cable. For instructions, see How do I charge my Fitbit device?
  2. Press the button located on the flat end of the charger 3 times (end if the USB cable), pausing for 1 second between presses. Then wait 10 seconds or until the Fitbit logo appears.
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after a few hours.
2 REPLIES 2
You posted in the wrong forum. I'll move your post to the Charge 5 forums.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
