03-21-2023
04:41
08:17
03-21-2023
04:41
08:17
After I updated to the latest version of my Fitbit Charge 5 watch, the battery performance dropped a lot from 7 DAYS TO ONE DAY
Hi @Andrei.ucu
Have you tried connecting the wwatch to the charger, plugging it into a power source and then pressing the button on the end of the charger. This will perform a restart, and hopefully solve your battery drain issue.
Best AnswerI tried and it doesn't work.
Best AnswerI think the only other option you've got is a factory reset.
Device Info
Clear User Data.
If this doesn't make any difference then it could be a hardware issue. For that you will need to contact customer support (here).
No fix worked for me when I had this problem last week. I was still under warranty so Fitbit is replacing it. I’m really frustrated because this is the second charge 5 I’ve had to replace in less than 12 months. I’ve been a charge user since they came out and I’ve never experienced this before. I used to have to replace the bands, not the charge itself.
yes, I will do that I still have a warranty for the watch and I will replace it
Best AnswerThanks for the advice but it still doesn't work. I will contact the customer support.
Best AnswerI'm having same issue, except my battery has been draining fast for a couple weeks. Yesterday I checked the battery and it was about 44%, this morning I woke up and my Fitbit was dead. Very exasperating. My last Fitbit didn't last a year and I decided to go with another since I have all my info on the app. If this keeps up, I'm making the move to Apple watch as much as I don't want to.
