Charge 5 battery is draining too quickly
Pause before doing the Charge 5 update
The update rendered my Charge 5 useless. It reduced the battery life from about a week to about a half hour. As it is no longer under warranty it’s pretty much done and there is no undoing the update so I’m basically out of luck
2 REPLIES 2
Welcome to the Fitbit community, @Dafonedude!
Sad to hear that your Charge 5 isn't working as expected. I'd suggest that you're trying to start things from scratch before throwing the towel. To do so, first sync your device to not lose any data it has tracked so far. Then please have a look here to see how to restart your device:
Charge 5 - Update, Restart, and Erase
If restarting your device doesn't improve battery run time, I'd recommend ersing it as described in the article I've provided above. Next set up your Charge 5 as described blow:
How do I set up my Fitbit device?
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Hi there, @Dafonedude. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. @Talahthas Thank you so much for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
