Charge 5 battery won't charge
Unable to change my Charge 5. Has gone totally flat.
1 REPLY 1
@PG25 Welcome to the Fitbit community!
Sad to hear that your Charge 5 isn't working properly. I'd suggest trying to restart your device by following these instructions:
1.) Connect your Charge 5 to the charging cable which has to be connected to a power source.
2.) Press the button located on the USB plug of the charger 3 times within 8 seconds, holding each press for about 1 second(!).
3.) Wait 10 seconds or until the Fitbit logo appears.
If this doesn't work for you, please contact Fitbit support to get further assistance as your Charge 5 might have technical issues:
Fitbit Support Contact
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
