Charge 5 blank screen
my fitbit charge 5 suddenly stop working with black screen(the back part still blinking green light)i tried restarting it by clicking the charger button 3x but still wont open,is there any repair center i can bring it to?,pls help
2 REPLIES 2
Hi, @tinz2022 unfortunately Fitbit does not offer any repair services or run or authorise any repair centres.  However, I would try the button restart procedure a few more times as a single restart does not always work.  You could also try changing the clock face .  If this solves the blank screen issue you can return to the previous clock face if preferred.
Good luck! I hope this helps.  Welcome to the forums.
Welcome to the Fitbit community, @tinz2022!
Sad to hear that you're having issues with your Charge 5. If what @Julia_G has mentioned doesn't work for you, I'd suggest contacting Fitbit support for further assistance as you device might be defective:
Fitbit Support Contact
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
