05-17-2025
23:35
10:40
05-17-2025
23:35
10:40
My Fitbit isn’t working anymore. Even trying to charge doesn’t work; the screen remains black.
05-18-2025 19:49
05-18-2025 19:49
Same here. Very sad
05-19-2025 10:44
05-19-2025 10:44
Hi there, @Garisanter. Welcome to the Fitbit Community Forums. @TheLevelOne It's nice to see you around! Thanks for bringing this to my attention. I'm sorry to hear that the screen of your Charge 5 devices are blank. I will do my best to help you with this!
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
05-20-2025
19:18
20:00
ManuFitbit
05-20-2025
19:18
20:00
ManuFitbit
mine is dead too and after trying all the steps multiple times, it is still nonresponsive. This has happened to about 4 of my fitbit devices over the years. These devices aren't built to last
What do we do if none of those work? I wasn't doing anything wrong and it just stopped working.
05-21-2025 05:33
05-21-2025 05:33
I called support and they gave me a code for 35% off on a new Charge 6. Mine was out of warranty, so I ordered one.
Regards ---------
05-26-2025 18:25
05-26-2025 18:25
Mine just shows a Blank screen. Tried resetting several times, Changing clock faces and even freezing it . Nothing works .
very disappointed really.
Best Answer05-27-2025 09:58
05-27-2025 09:58
my screen went blank this morning. tried it all - soft start , hard startup , update app, firmare... still nothing. i now it workign in the background. its just the screen.
05-27-2025
12:52
14:04
MarioSFitbit
05-27-2025
12:52
14:04
MarioSFitbit
Same!! I'm so tired of my Charge 5 becoming unresponsive!! It's so frustrating!! None of the step by step instructions have worked.
That's the same exact thing I am experiencing, too!
Moderator edit - merged messages
Best Answer05-27-2025 15:23
05-27-2025 15:23
Same here! Suddenly stopped, red flashing light and blank screen. Been on charge all day. App not synching, restarts doing nothing. Even tried forgetting device on bluetooth, now it wont find ut again 🤦🏻:female_sign:
Best Answer05-27-2025 22:27
05-27-2025 22:27
I am also struggling with the same issue. Is there a solution for this?
Best Answer05-28-2025 05:00
05-28-2025 05:00
I gave up on trying to fix mine, so I bought a new 6. I had my 5 for 3yr and wore it almost every day so it doesn't owe me anything. Good luck!
Best Answer05-28-2025 06:43
05-28-2025 06:43
I tried all of these steps and they did not work. My app is showing it synced last night at 7:58 with a full charge. As of this morning the screen is black, it will not reboot using any of the methods.
