I'm trying to use phone connected gps to track walks, when I open walk mode and hit start the gps connection times out without connecting. The phone GPS works fine on the phone, all permissions are allowed. I've restarted the Charge 5 and the phone. The phone is a Pixel 6. Any ideas?
05:45
15:13
11-16-2021
05:45
15:13
Hi, thank you for sharing this information about the trouble you've been experiencing with your Charge 5, @narf57.
Before considering other options, make sure to follow the steps suggested in this article to use the GPS feature.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart, as this has been useful for other users experiencing something similar. Preferably, I recommend that you try the three pulse restart method described here below:
Hope this helps, I'll be around.
Best AnswerProbably should have posted this earlier, but the problem resolved itself , probably due to a reboot of either the phone or the Fitbit. And to clarify, the issue was about eonnecting to the phone for GPS, not the GPS in the Fitbit itself.
12-14-2021
05:47
15:23
