11-18-2022
08:59
09:41
DavideFitbit
11-18-2022
08:59
09:41
DavideFitbit
My Charge 5 is losing charge quick this is a replacement already. My first Charge 5 would not charge up. This replacement is losing charge quickly. And when i hook up to charge it up . It does not show that it is in charging mode.
09:40
06:15
11-19-2022
09:40
06:15
Hi, welcome to the Fitbit Community forums, @Trevnune1.
I appreciate all this information that you've shared about the inconvenience that you've been having with your Charge 5.
Before considering other options, please make sure that you've followed the steps provided in this article. In addition, try to perform a restart following the steps listed here below, this has been useful for other users experiencing something similar:
The battery can last up to 7 days; because battery life is affected by use and other settings, actual results may vary, but the battery shouldn't be draining only after one or two days. Keep in mind that some of the feature that can drain the battery more rapidly are:
In case the battery is not charging at all, I also recommend that you follow the steps listed in this article.
Hope this helps, I'll be around.
12-08-2022
06:39
06:15
12-08-2022
06:39
06:15
@Trevnune1 That's great news! Thank you for sharing this update.
See you around in the Community.
