Charge 5 is not vibrating
ANSWERED
How do I control vibration on Charge 5?
1 BEST ANSWER
Accepted Solutions
Hello there, @KCoy. Thanks for stopping by in the Fitbit Community Forums and already checking your settings as suggested above.
In addition to the steps you've done, please try removing the alarm and then adding it once again. You can find instructions on how to remove alarms by clicking here. Basically what you want to do is:
  1. Sync your Fitbit to your account.
  2. Restart your Charge 5.
  3. Remove the alarm.
  4. Sync your Fitbit.
  5. Add the alarm.
  6. Since once more.
6 REPLIES 6
Welcome to the Fitbit community, @Plancer!
To set up notifications and corresponding vibration alerts on your Charge 5, there are several points to be considered. Please take a minute and have a look here:
How do I get notifications from my phone on my Fitbit device?
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
Hi there, @Plancer. Welcome to the Fitbit Community Forums.
In addition to what @Talahthas has suggested, I'd also recommend taking a look at this help article Why didn't my Fitbit device alert me?
My alarms are not alarming/vibrating.  I have three set to alarm everyday.  I have checked the settings and sleep mode and DND are off.  A week ago the alarms worked.  Any suggestioms?
  5. Add the alarm.
  6. Since once more.
Mine too doesn’t vibrate. Many notifications come through and I can view them on my Charge 5, but it doesn’t vibrate to alert me when a notification comes through, like my Charge 2 did. Is this normal?
Hi there, @lekhanani. Welcome on board! Thanks for the details provided in your post about the issue with your Charge 5.
If you haven't done so yet, please take a look at the suggestion I've provided here.
