Charge 5 screen blank
The screen on my Charge 5 is blank.  Otherwise seems to be working fine, syncs, records steps, etc.  Tried the 3 button press reset multiple times.
11 REPLIES 11
Welcome back to the Fitbit community, @longtime_user!
Sad to hear that you're having an issue with your Charge 5. Please try if changing the clock face will fix this. To do so, please follow this instruction guide:
Clock Faces and Apps - Change the clock face
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Hello. I have the same issue.  The screen is blank ( solid yellowish color when awakened) and I changed the clock face three different times without success. This unit was purchased  less than eight months ago when I bought it to replace a malfunctioning charge 5 to keep my streak going. I am now lest than a week from a continuous yearlong step goal. Tell me please how to reset when the screen does not communicate it’s current state.
Me, too!
Did online chat with customer service, after attempts to reset and change
the clock face, they offered a one-time replacement. Charge 5 was ~1 year
old.
It took many attempts over a week, tried it again just now, and it works.  If it didn't, I was going to go back to Charge 4, because I didn't have those problems with #4.
Welcome back to the Fitbit community, @tinman25!
If restarting your device didn't get it back to work, I'd suggest contacting Fitbit support. As you mentioned having purchased your Charge 5 less than eight months ago, it should be covered by Fitbit's warranty, so they should able to replace it.
Fitbit Support Contact
Stefan
Great to hear that you'll be getting a new device, thanks for that feedback, @longtime_user!
Stefan
Glad that restarting your device finally has worked. In some cases you really have to do this restart procedure a few times to get it to work.
Thanks for your feedback, @gracemf!
Stefan
I talked to customer service as well, I had already tried changing the clock face three times but still had a blank ( yellowish) screen. I was told they appreciated me trying the solutions offered online first and would be sending me an email to let me know of my next step. Less than 8 months old and I’m within 5 days of one year consecutive step goals being met. As long as my unit was still registering data I was tolerant but now my battery level is dropping like a stone. I know I will make my one year goal but it is incredibly disappointing that my second unit in a year is not capable of performing what it was made to do.
Glad that the support team found a solution to get you back on track again. Thanks for your feedback, @tinman25!
Stefan
Hello, thank you for acknowledging my posts. To be clear, I was told there would be an email but I have yet to receive one. The lack of acceptable response is jeopardizing more than 8 years loyalty and my  premium subscription.
