12-26-2023
00:35
06:28
12-26-2023
00:35
06:28
My Fitbit was given as a gift last May 2023. I charged it and restarted it. However, even if the battery says 100 %, it will be on for a while less than 10 minutes on my hand, then turns off.
I kept on troubleshooting it by fully charging and restarting but still remains unlit or not working Please advise.
thank you
12-26-2023 06:31
12-26-2023 06:31
Hi there, @MPurple. Thanks for stopping by in the Fitbit Community Forums. It's sad to hear that your Charge 5 is still not working properly despite the steps you've done so far. I understand where your concern is coming from as your device is not that old. I'll do my best to help you!
As a first approach, please make sure you've restarted your Charge 5 as described here.
If the restart doesn't work and your Charge 5 doesn't vibrate during the restart process, please follow the steps below:
Best Answer12-29-2023 15:29
12-29-2023 15:29
Hello,
I troubleshooted and did all the steps you mentioned, my Fitbit still not working
please advise
thank you
Marilyn
01-09-2024 01:04
01-09-2024 01:04
The only sound advise that you gave to MPurple was to restart the fitbit. It has nothing to do with the charging cable. I am experiencing the same thing as many others are and I believe that it has to do with a software update by fitbit. I called customer service and the only thing that they could tell me was that it might be the third party clock face. If this is an issue, why put third party clock faces on the tracker? I have had all fitbit charge watches and never experienced this until mid 2023. I wish the company would fix this issue with so many customers complaining about it. I've heard that Fitbit has lost a lot of customers because of this...I am also now looking into a different fitness tracker elsewhere.
Best Answer01-09-2024 20:34
01-09-2024 20:34
