01-06-2025
20:28
07:16
01-06-2025
20:28
07:16
Keep shutting down for no reason. Restarts when I connect to charger then 2 or 3 days later does the same thing. Unable to factory reset
Best Answer01-07-2025 07:21
01-07-2025 07:21
Hi there, @Francisd0. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Charge 5 is crashing itself. I understand your concern, I will do my best to help you with this!
Please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
01-07-2025 09:37
01-07-2025 09:37
01-07-2025 11:09
01-07-2025 11:09
Hello my Fitbit watch goes off when I remove it from my hand, when I charge it it is ok again
Best Answer01-07-2025 11:23
01-07-2025 11:23
Ps I also changed my settings to display always on
Francisd0
Best Answer01-09-2025 19:13
01-09-2025 19:13
Had to restart it again tonight so the solution didn't work
01-12-2025 06:46
01-12-2025 06:46
Bought Samsung Fit 3. Not happy with Google. Both charge 5 and Pixel 7 not working properly. Going bact to Samsung when my mobile contract is up.
