12-25-2021 13:50
12-25-2021 13:50
Any help the latch that holds the band on my charge 5 is broken. So will not hold the band
Best Answer12-25-2021 14:14
12-25-2021 14:14
My experience is that you will get a replacement if you contact them via e-mail fairly easy (needs to give proof)
Best Answer12-26-2021 18:23
12-26-2021 18:23
Does this mean the Charge 5 has a plastic connector for the wristband like the Charge 4 does? If so, sounds like it will have the same problem with the connector being plastic and breaking. Bummer. In the 2 times it has broken on my Charge 4, they have replaced it, but it is a poor design.
