07-26-2022 23:46
07-26-2022 23:46
Charge 2 and 4 were great. I am now using Charge 5 for a couple of weeks and that one is hopeless. Goodbye Fitbit.
07:12
04:09
07-27-2022
07:12
04:09
Welcome to the Community forums, @Bradjong.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
Before considering other options, I recommend that you try restarting the device using the three pulse restart method described here below:
Keep in mind that you need to sync through the Fitbit app and not through the Bluetooth settings on your phone. In addition to the restart, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
07:12
04:09
07-27-2022
07:12
04:09
Best Answer07-30-2022 06:33
07-30-2022 06:33
Davide, thanks for your information. It solved my problem. I was not aware of the following requirement:
"If you use more than one phone or tablet to sync, make sure the other device isn't nearby. If the device is nearby, turn off Bluetooth on it."
I use an iPhone but, accidentally, the Fitbit app was also running on my iPad.
Once again, many thanks.
Regards,
Bradjong
18:02
06:32
DavideFitbit
08-04-2022
18:02
06:32
DavideFitbit
I’ve the same problem with a new Charge 5 that I’ve only had around one week!! All fine at first but won’t sync since iPhone updated this morning. I’ve contacted customer support 3 times via live chat - had lots of repetitive advice, tried everything including all that you’ve detailed above, and still not joy. My iPhone just can’t find the device despite it being plugged in and charged!! Any help please? I hesitated to buy another Fitbit due to screen problems with charge 3 but like lots of things about the Fitbit. I can’t believe I’m having problems within only 1 week!!!
Regards
Sally
Moderator edit: format
06:31
07:34
09-01-2022
06:31
07:34
@Bradjong That's great news! Thank you for sharing that you were able to resolve it. 😁
@sallyjm I'm sorry to see that you already tried all the steps mentioned earlier and that you're still experiencing the same problem. In this case, I do recommend that you continue the communication with the Customer Support team. Keep in mind they always need to make sure that all basic troubleshooting steps have been exhausted.
Thanks again for sharing all your comments and feedback.
