Charge 5 not charging
My Charge 5 was not holding a charge two days ago and now is not charging at all. I see Fromm other posts that this may be a common problem. Has anyone solved this problem or received support from Fitbit? I’ve only had this device for 9 months, up until now it worked fine.
1 REPLY 1
Welcome back to the Community forums, @Nanbc. .
Thank you for the information provided regarding the issue you're experiencing with your Charge 5.
If this is related to the battery, please let me know if you already tried all the steps provided in this article
If the device is charging, but the screen is completely black, make sure that you've also completed the three pulse restart procedure using the charging cable, as described here
I'll be around.
