09-27-2021
01:19
12:27
SilviaFitbit
09-27-2021
01:19
12:27
SilviaFitbit
Hi Fitbit team
got my charge 5 on saturday. I charge it , set it up without failure. I have weared it since saturday . But i have the same problem i had with charge 4. it will not hive me a sleep score and will not syncronize automatically in the morning. I must force it. This is frustrating! Also got some problem according to Get it record active minutes into my daily goal. I must set training manually for just a walk. Anyone Else having these problems? Fitbit team, pls answer this topic. Thanks
09-29-2021 12:32
09-29-2021 12:32
@Merete67norway Hi there. Thanks for the detailed information shared.
I see where your frustration is coming from. Take into consideration that in order to have sleep score, your Charge 5 needs to track sleep stages. May I know if you're getting sleep stages or only sleep pattern?
Check out the following scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
In regards to the syncing difficulties you're experiencing, follow this syncing troubleshooting.
Hope this helps.
Best Answer09-29-2021 13:08
09-29-2021 13:08
As told i have got sleep stages the last two nights. But i had to put watch in sleep mode when going to bed. Should it be necessary to put in sleep mode for getting sleep score and stages. I will look at the troubleshootings you gave me. Thanks
Best Answer10-02-2021 17:23
10-02-2021 17:23
@Merete67norway Thank you for getting back.
There's no need to track sleep using the Fitbit app as by only wearing your Charge 5, it will automatically track your sleep. Please check the tips mentioned above and continue monitoring its functionality.
Have a nice day.
10-03-2021 01:26
10-03-2021 01:26
I have now got sleep score the last 6 nights. By putring watch in sleep mode when i go to bed. I will try to not put it on sleep mode and ser tonight. Just put it in sleep mode automatically. Just got so used to do it. Will come back with outcome tomorrow .
10-05-2021
17:13
17:27
10-05-2021
17:13
17:27
@Merete67norway Thanks for the details shared.
Hope you continue enjoying your Charge 5 and taking advantage of the features it has.
Have a good week.
