12-30-2021 09:19
12-30-2021 09:19
Starting last night- will not accept a charge and will not sync. Anyone else?
12-31-2021
05:59
10:44
12-31-2021
05:59
10:44
Hi, welcome to the Fitbit Community forums, @Wren2012.
Thank you for sharing this information about the trouble you've been having with your Charge 5.
Before considering other options, please make sure to follow the steps in this article, as this has been useful for other users.
In addition, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Hope this helps, I'll be around.
12-31-2021 21:19
12-31-2021 21:19
Same issue here, also started yesterday after a couple months of perfect operation. Won’t sync (times out) even tho it shows connected. Tried toggling Bluetooth on/off, restarting device, restarting iPhone (13 pro), deleting and reinstalling app. Charge is at 46% but now it won’t charge either. It never gets wet. The watch itself is correctly tracking s
01-07-2022
17:14
10:43
01-07-2022
17:14
10:43
@SunsetRunner Thank you for your reply and for confirming that you're experiencing the same inconvenience with your Charge 5.
Could you please also confirm if you've tried all the troubleshooting steps mentioned here earlier and if you're still having the same problems after that?
I'll be around.
Best Answer01-07-2022 20:45
01-07-2022 20:45
Yes I did all of that. What I finally did was a full reset and wipe as if I was going to give it to someone else, then set it up as new. It’s worked *almost* fine for the past week now. By “almost” there is one odd thing: when I sync to my iPhone 13 everything comes over fine except the battery level. That’s stuck at 38% even as the actual battery (and % display on the Charge 5 itself) changes appropriately as I charge and use.
07:40
10:43
01-20-2022
07:40
10:43
@SunsetRunner Thank you for sharing this update. It's good to know that your device is syncing properly again.
Regarding the inconvenience with the battery level not updating in the app, the team is already aware of this problem and they're currently working to resolve it. In the meantime you can force quit the app as described here and reopen it to see the correct % within the iOS app. Rest assured that the battery percentage displayed on your Fitbit device should always be accurate.
See you around.
