02-29-2024
03:50
11:31
ManuFitbit
02-29-2024
03:50
11:31
ManuFitbit
My charge 5 no longer synces
Moderator edit: clarified subject
02-29-2024 03:53
02-29-2024 03:53
Same issue, not syncing my Charge 5. Restart device didn’t work, charging it didn’t change anything, no updates available. Need assistance.
02-29-2024 06:48
02-29-2024 06:48
I’ve been having the same issue with my charge 5 for about 3 days. Can’t get it to sync. Tried all the things and nothing is working.
02-29-2024 11:27 - edited 02-29-2024 11:30
Welcome to the community forums @Kcarlat @LilCampet @Yowsers
Thank you for taking the time to share the inquiry regarding Charge 5.
Please, follow these steps:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
02-29-2024 14:23
02-29-2024 14:23
I’ve done all of that. I never had this issue with previous versions. Pretty disconcerting.
03-01-2024 04:28
03-01-2024 04:28
Very strange! Suddenly this morning the watch and app synced! My bet is that an update took place to fix this issue since several of us reported the issue but I don’t know for sure.
03-01-2024 04:46
03-01-2024 04:46
Mine has alsp stopped and I've tried everything listed here. My charger dowwbnor have that button so I restarted from the actual phone.
Best Answer03-01-2024 05:14
03-01-2024 05:14
They was supposed to say
Mine has alsp stopped and I've tried everything listed here. My charger doesn't have that button so I restarted from the actual charger screen
07:26
06:12
ManuFitbit
03-01-2024
07:26
06:12
ManuFitbit
I’ve tried all these steps, except on the tracker restart option my charger doesn’t have the button so I restarted through the tracker itself. And now when trying to connect the device through the app, it won’t connect.
also now when I plug my device to charge, it won’t charge. Which is weird since I charged it yesterday with no problems
Disregard, found button on FLAT part of charger (part that plugs in near the wall, not the end that connects to Fitbit device)and resetting that way worked and then I was able to connect device. Doesn’t seem to have collected any data from 11pm last night though
