10-16-2021
11:08
16:14
SilviaFitbit
10-16-2021
11:08
16:14
SilviaFitbit
Fairly consistently underreporting sleep data
10-16-2021 12:59
10-16-2021 13:07
10-16-2021 13:07
Best Answer10-17-2021 06:56
10-17-2021 06:56
Having same issue. Just cancelled my premium membership because I only received detailed info for one out of the last four nights. The only info synced consistently is the heart rate. All others are missing data.
10-17-2021 08:21
10-17-2021 08:21
If you are receiving simple sleep
Note: I find if the heart rate is turned off, fitbit says that they do not know why.
@Smplay in what way do you feel sleep is under reported?
The Red Arrows point to simple sleep
The Green Stars say that I made my sleep goal for the night.
Note about March 21. I have 2 more sleep periods not in the screen shot.
04-09-2022 23:23
04-09-2022 23:23
It's the same with me, I have tried everything they mentioned on their website on how to ensure a good fit (it doesn't slip at all) and yet it's unable to measure data 😕
04-10-2022 04:58
04-10-2022 04:58
Same here. Last night it recorded only 2 hours of sleep….I definitely slept more than that. Fit bit is on and charged. I’m wondering if certain sleeping positions affect the recording. Haven’t been able to find answers on that.
04-12-2022 04:39
04-12-2022 04:39
I'm having a similar problem with my charge 5. Every 4 or 5 days I get a simple sleep notification even though the device was not moved from my wrist. I reset and it's good until the next time. Never had this problem with my charge 3. I doubt I'll renew my premium subscriptions should this problem persist
