11-14-2022
17:22
09:55
DavideFitbit
11-14-2022
17:22
09:55
DavideFitbit
Charge 5 “reminders to move” will not turn on …showing “disabled” even after I toggle it off/on … I have exhausted every known option and it still shows “disabled” even after I toggle back on!
11-19-2022 09:54
11-19-2022 09:54
Hi, welcome to the Fitbit Community forums, @keyboards49.
Thank you for sharing all these details about the inconvenience you've been having with your Charge 5 and for confirming that you already tried a few troubleshooting steps.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they shared some instructions with you. In this case, they will let you know how to proceed.
Let me know if you continue to experience the same inconvenience.
See you around.
12-06-2022
04:08
07:11
DavideFitbit
12-06-2022
04:08
07:11
DavideFitbit
This is affecting my new Fitbit Charge 5 as well and I don’t get the reminder on my device to get up and move. All settings are correct and it’s still not working properly.
Moderator edit: format
12-06-2022 04:12
12-06-2022 04:12
Could you share those instructions so the rest of us with this problem can fix it to please?
12-23-2022 07:09
12-23-2022 07:09
Welcome to the Fitbit Community forums, @Laur67 @IonaJoJo.
Thanks for sharing that you experienced this issue with your Charge 5 as well.
Let me know if you're having trouble to receive any other type of notifications or if this is happening only with the reminders to move. In the meantime, make sure this feature is turned on following these steps:
If the feature is already turned on, you can also try changing the time when you can receive reminders to move. You can change the hours or days of the week that you track your hourly activity goal (for example, 10:00 a.m. to 5:00 p.m. on weekdays). You can find more information in this article.
In the meantime, make sure the Do Not Disturb Mode and the Sleep Mode features are turned off, as these features prevent the device from vibrating and receiving notifications, reminders and goal celebrations.
Hope this helps, I'll be around.
