04-09-2024
09:44
09:48
04-09-2024
09:44
09:48
Charge 5 goes black reset works for about 12 hours then black again.
Charge & APP Battery % don't match but do show a decent amount of charge.
Please help!
Hi there, @Mike1055. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the screen of your Charge 5 is going blank constantly. I will do my best to help you with this!
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best AnswerI (correctly) reset again, charged, and changed the clock face last night. So far it's working but we'll have to wait to see if it lasts.
When I connected and reset the time on the Charge was 11:47 A.M. (That's apparently when it froze) & it seems like it was the exact same time
that it froze the day before...I just can't stop troubleshooting/looking for clues...
The battery % did synchronize, I'm hoping that is a good sign for all of it.
Do you happen to know if there is any way to reset the Charge 5 without connecting to the charge cable?
Thank you!
Mike Vail
p.s. I'll update you if/when it lasts for a day or 2.
Best AnswerHello @Mike1055
You can restart your Charge 5 from the Settings menu on the device:
These steps are also available in the How do I restart my Fitbit link that @MarreFitbit provided
Note: This is to restart your Charge 5 which turns it off, then back on. This is not the same as a Factory reset, which clears all the tracked user data in the device.
I only know of 1 way to do a factory reset on the Charge 5 and that's from the Settings menu on the device:
Unfortunately, you have to be able to see the screen in order to do the factory reset. Like many other users, I really wish there was a physical way to do the reset.
Best AnswerI lasted about 2.5 days then froze, reset & froze again in just a few hours(black screen, no function, ...)
