07-26-2024
20:34
05:29
LizzyFitbit
07-26-2024
20:34
05:29
LizzyFitbit
07-27-2024 16:55
07-27-2024 16:55
Meeee!!! My Charge 5 came back to life yesterday! The sleep & heart rate data isn't working yet, but I have HOPE!!!
Best Answer07-29-2024 15:09
07-29-2024 15:09
Hello @Peepot
Thanks for letting us know that you were able to get your Charge 5 working again.
Regarding the heart rate & sleep data, do you see a green light on the back of your Charge 5? That's the heart rate sensor. If you don't see it, check the Settings menu on the Charge 5 and confirm that Heart Rate is turned on. It might have gotten turned off when it wasn't working right.
Best Answer07-31-2024 08:22
07-31-2024 08:22
I keep having to plug it into it's charger for just a minute and then it works again.
Best Answer07-31-2024 08:24
07-31-2024 08:24
i have the same problem with mine tried resetting many times which hasn't solved anything
