10-21-2024
13:39
10:24
FatimaFitbit
10-21-2024
13:39
10:24
FatimaFitbit
I have had my charge 5 for 2.5 years and the display (over the last week) has started to flicker and has now the charge 5 screen is black/blank - still works in regards to logging information.
I have tried resetting the app and the device still no luck - out of options so unless someone has a magic answer I will have to buy a different make of fitness wearable!
Best Answer10-24-2024 03:47 - edited 10-24-2024 03:51
Same here, tracking and sync with the app works but screen is blank and doesn't respond.
Is there any way to reset the charge 5 when the screen is blank and not responding? Plugging the charge 5 in and pressing the button on the cable does nothing...
Best Answer10-24-2024 04:09
10-24-2024 04:09
They are replacing mine
10-24-2024 04:12
10-24-2024 04:12
Have the exact same issue but after I water locked it , black screen but will download and show Fitbit image and nothing else. Cannot hard reset it either
Best Answer10-24-2024 04:49
10-24-2024 04:49
Also app indicates that there is an update available. When I update, it says that the update was successful but there is still an message in the app saying that there is an update available.
Still stuck on black unresponsive screen...
10-25-2024 06:10
10-25-2024 06:10
Is yours still in warrantee Timpo?
Best Answer10-25-2024 06:42
10-25-2024 06:42
A coouple of weeks ago my Charge 5 started to "run out" of battery after only a couple of days but, when I put it on the charger, the device said it still had some charge left (lowest being at 16%).
Was wondering if it's a software fault that needs an update or the device itself is faulty.
Bought it in September 2023 (Currys/PC World, UK).
06:47
07:18
FatimaFitbit
10-25-2024
06:47
07:18
FatimaFitbit
So, been offered a whole 35% off a new Fitbit as I'm out of warranty. 🤦
Bit of a joke really, release a software update to kill off older Charge 5s then force folk to buy new instead of fixing the update. 😡😡😡
TIA
Moderator Edit: Word choice
Best Answer10-25-2024 08:35
10-25-2024 08:35
You were offered more than me, regardless if they offered 80% I would never buy their products again. Looking at samsung myself, check reviews for them
Best Answer10-25-2024 14:14
10-25-2024 14:14
Yes,but only because it was already replaced in November last year
Best Answer10-25-2024 14:51
10-25-2024 14:51
I missed out by about 14 days, I do believe though they have failed to provide a service that was originally purchased for. The product is no longer working due to no fault of the consumer. I do think more should be done from fit bit side to continue the service. Bitter pill to swallow but hey ho lesson learnt
10-25-2024 15:28
10-25-2024 15:28
If it was a failed software update that bricked them everybody should be recompensed
10-25-2024 22:57
10-25-2024 22:57
Try telling them, asked for a refund but due to policies(yawn), non refundable.
05:54
07:19
FatimaFitbit
10-26-2024
05:54
07:19
FatimaFitbit
Same problem here. Started just a few days ago. I've had all the previous Fitbit in this style and they always start messing up at about the 2-3 year mark.
10-26-2024 06:26
10-26-2024 06:26
Just after the warranty runs out.
What a coincidence! 🤔
Best Answer10-27-2024 09:08
10-27-2024 09:08
I've done a few hour long session on chat 'help'. I went from having a blank screen that would only display white connected to the charger to a watch that wouldn't sync. I got it syncing all by myself by letting it get to zero battery. Now I'm back to a battery that goes from 100% to zero in a few hours. All chat could say is they know there's a problem and they're working on it but couldn't say if it would be days, weeks or months.
Best Answer10-27-2024 09:13
10-27-2024 09:13
That's more than was admitted to me. 😡
"Just get a new one" 🤬
Best Answer10-31-2024 02:23
10-31-2024 02:23
They have to say that of course
Best Answer10-31-2024 03:41
10-31-2024 03:41
All this started with a faulty update resulting in black / blank screens and inability to sync. i got over that but now my battery dies in a few hours. @help gave me instructions on improving battery life but i think that ship has sailed. I could always strap a powerbank to my arm and leave it on charge while i wear it i guess. I think the whole thing is a fiasco similar to the Windows update by Crowdstrike a few months ago.
Best Answer10-31-2024 05:45
10-31-2024 05:45
Does anyone have a phone number to talk to a Fitbit support technician? I'm tired of dealing with this texting in my problems
Best Answer10-31-2024 06:13
10-31-2024 06:13
@Woody25 you'll need to contact customer support by going to this page - click to go there - and filling out the required fields. As you progress, you will go from page to page, adding any required information. Ultimately you will arrive at the place where you can decide to receive or to make a call directly to support. It's the way you'll get things going.
