08-10-2022
13:20
09:07
DavideFitbit
08-10-2022
13:20
09:07
DavideFitbit
I am having a problem in my Fitbit Charge 5
The screen is going on and off , has vertical lines too
How can I fix it
Moderator edit: format
Best Answer08-11-2022 09:06
08-11-2022 09:06
Hi, welcome to the Community forums, @AJAlfares.
I appreciate all the information that you've provided about this inconvenience with your Charge 5.
If you haven't done so already, here are some general recommendations that are usually helpful with any type of display issues:
Hope this helps, I'll be around.
Best Answer08-11-2022 19:01
08-11-2022 19:01
With all due respect sir, I am noticing you making this same kind of comment on many recent posts about issues with the Charge 5 model. Perhaps instead of telling all of us to try steps that we likely have already tried prior to seeking advice on this forum, you and your team should be looking into why so many of us are having the same problem. I did not start my own thread on this discussion board because I figured there were already so many threads posted so close together that Fitbit tech support would already be looking into the issue. Your comments suggest otherwise.
08-13-2022 03:17
08-13-2022 03:17
07:25
06:40
09-06-2022
07:25
06:40
@wildangelgirl I appreciate all your comments and feedback about this. This information has already been shared with the team, but we haven't received other updates for the moment. In the meantime, it's recommended to try the steps mentioned earlier and continue the communication with the Support team if the issue persists. Keep in mind that every case is evaluated individually.
@AJAlfares Thank you for sharing your feedback about this. Let me know if you continue to experience the same inconvenience after the steps suggested earlier.
I'll be around.
