06-01-2023
17:48
04:27
06-01-2023
17:48
04:27
Best Answer06-02-2023 04:28 - edited 06-02-2023 04:31
Hi there, @s10r. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out. I understand how you must be feeling.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Regarding your inquiry about the battery, please note that the battery on your Charge 5 is not replaceable nor interchanged. We as Fitbit do not do it or suggest to do it as it could permanently damage your Fitbit device.
06-02-2023 04:47
06-02-2023 04:47
OK, so I have now got your attention.
To explain the problem clearly, last week I faced a black screen problem. There is already a discussion on the same here: https://community.fitbit.com/t5/Charge-5/Charge-5-black-screen/td-p/5154973.
As you can see, several users are affected by this issue. I did try three pulse restart method and changing the clock face. None of which worked for me. Fortunately, unlike several others, I could sync my Fitbit with my mobile app and I could fix the issue upon installing the firmware update. (Lucky, I guess: I thought at this point). Little did I know, I would face the same issue regularly. Upon fixing this issue around 3 days back, I have faced the same issue twice after that. (fixed by putting the tracker on charging and using three pulse restart method). At this point, I see no permanent solution.
Another major issue, as pointed out by several people on the above-mentioned thread; the battery has gone for a toss now. Eariler, I could easily use my tracker upto 7 days minimum. But now, not so sure. I fully charged my tracker, next day it went black screen and when I put my charger battery was at 36%.
Have you guys found what's causing this issue? I have not seen the reason behind this issue even after going through several posts on the same issue.
Hope you take this issue seriously and provide a permanent solution to the community.
