01-27-2024
19:01
10:41
CrisVillaFitbit
01-27-2024
19:01
10:41
CrisVillaFitbit
My Charge 5 goes into ECG mode and will nor go back to the clock face. I don't want the ECG mode! How can I turn it off?
Moderator edit: edited title to clarity.
Best Answer01-28-2024 10:44
01-28-2024 10:44
Hi and welcome to the Fitbit Community, @Bair.
Thanks for explaining your situation in regards to your Charge 5 having the ECG app showing on the screen. Can you explain to me if this happens whenever you do something in your Fitbit or does it goes randomly like this?
I recommend you to restart your Charge 5, you can check instructions on how to do so here.
Best Answer01-28-2024 12:53
01-28-2024 12:53
Hello @Bair
I've accidentally started the ECG app on my Charge 5 and discovered that if I tap on the display/screen multiple times, the multiple taps will get me out of the ECG app and back to the clock face.
Unfortunately, there curretly isn't a way to remove the ECG or EDA tiles from the Charge 5 so they don't appear at all.
