01-12-2024
06:21
10:02
ManuFitbit
01-12-2024
06:21
10:02
ManuFitbit
My Fitbit Charge 5 Screen remains black. I have attempted to restart it by all means suggested; holding charger button for 5 seconds; holding charger button for 15 seconds etc; I have tried different sockets; different plugs etc, all to no avail. The pebble is taking a charge and is buzzing, communicating with the software etc, just a completely black screen. Please suggest next steps, thanks
Moderator edit: clarified subject.
01-12-2024 09:56
01-12-2024 09:56
Welcome to the forums @AlnRugby.
Thank you for providing the details about this situation with your Charge 5 and for trying to fix it on your own.
I'd ask you please sync your device following the steps listed in this help article.
In addition, change your clock face as indicated here.
Best Answer01-13-2024 17:22
01-13-2024 17:22
Hello! I also have the black screen of death. Don't know why; it happened suddenly a couple of hours ago (around 5:00 Saturday Jan. 13). My Charge 5 continues to sync with the app. I know this because I can see that my steps change, as does my bpm and battery charge indicator. The battery seems to be draining quickly, though. As you suggested to @AlnRugby, I tried to change my clock face by following the directions at the link you provided. My app confirms the clock face was changed. I'll just have to take the app's word for it, since my device screen remains pure black & unresponsive to all attempts to activate it. Please tell me how to fix it. I could live with it because it does continue to track & sync, but I really need to know what time it is! My alternative will be to buy an Oura ring & use the watch I used before buying Fitbit.
01-14-2024 07:45
01-14-2024 07:45
I’m having the exact same issue as describe above. Also happened yesterday pm.
01-14-2024 08:10
01-14-2024 08:10
VFP50 -- Just curious; did you ever get a visible screen once it went black? I haven't. What's more, this morning my app again shows "update needed." Since I just updated it yesterday to the 20001.194.91 version, I'm hoping that this update will fix the black screen problem. Fingers crossed.
Best Answer01-14-2024 08:41
01-14-2024 08:41
I too have the same problem and it happened yesterday pm as well. Tried everything suggested and still just a dead, black screen.
01-14-2024 14:14
01-14-2024 14:14
I'm having the same issue and tried everything mentioned above.
01-14-2024 15:17
01-14-2024 15:17
Same problem of blank screen since yesterday not able to charge the charge 5 nor update it , some update tracker notification is coming in the app even after it is updated to 194.
01-14-2024 16:36
01-14-2024 16:36
Mine has that same notification. I thought it meant a new update to address the black screen problem. If that's what it means, my fitbit won't update.
01-15-2024 05:22
01-15-2024 05:22
Yes but only once and very briefly.
01-15-2024 10:48
01-15-2024 10:48
Same thing has happened to me - I got a flash of an ultra bright flouro-green screen with Fitbit logo then factory setting clock face showing and now nothing! Very frustrating …
01-15-2024 13:10
01-15-2024 13:10
I also have the black screen of death and my battery drained to 0% quickly. It won't seem to take a charge at this point despite being plugged in. The only thing I can get on the screen is the logo, and an indicator that reads 01/10, 0%, 11:45pm. My app has not synced since 01/10, shortly after software update and will not sync. I followed the various online instructions to reset but nothing has worked. My Charge 5 will no longer pair to my phone and I cannot get my phone to see it via Bluetooth. Any suggestions for those of us who have the black screen of death and can't get the basics (like bluetooth, app sync) to work?
01-15-2024 14:39
01-15-2024 14:39
Wow! I wish I could help you. I guess I'm lucky that at least my app syncs.; don't know how accurate it is, though.
Best Answer01-15-2024 16:19
01-15-2024 16:19
I finally just got support to respond to me with the same issue - they seem to think it is an isolated battery issue not a software issue despite so many people with the same issue. They told me I need to check warranty....!
01-15-2024 17:35
01-15-2024 17:35
They're just lazy. Don't want to find out what the real issue is. Their heads hurt to think it through.
Best Answer01-15-2024 19:41
01-15-2024 19:41
Also how can it be a battery issue if some of ours are charging? Too annoying!
01-15-2024 20:04
01-15-2024 20:04
01-15-2024 20:08
01-15-2024 20:08
01-16-2024 05:58
01-16-2024 05:58
Same black screen charge is all right it continue to count steps I see them at the phone.
Third Fitbit and the last one .
01-16-2024 11:42
01-16-2024 11:42
I contacted customer support and was told someone would reach out to me about warranty options. We had exhausted all troubleshooting options because my battery remains at 0% despite sitting in the charger with clean connections. Just unfortunate how one moment it was working fine and i never had any issues, and the next it's the black screen and battery of death. Boo...
