11-27-2022 05:50
11-27-2022 05:50
Bought a Charge 5 to replace a Charge 2 and have been very disappointed that in the 2 weeks i’ve had it, it has never recorder anything other than sleep bars, never once sleep stages. I’ve performed all the step suggested in this and other forums. Never had this problem with my charge2!!
need this resolved or will return and go with another manufacturer!!!
Best Answer11-28-2022 03:32
11-28-2022 03:32
@dbWizard That is most unusual behavior. Is your heart rate monitor working? That's the only reason I can think that it's giving you the generic sleep graph without stages. I know you said you tried a few things, but did you try removing the sleep tile from the app and re-adding it? Also, are you telling the Fitbit app when you're going to sleep (by selecting Begin Sleep Now) or are you letting it naturally record you falling asleep?
11-28-2022 03:32
11-28-2022 03:32
11-28-2022 03:53
11-28-2022 03:53
11-28-2022 05:18
11-28-2022 05:18
@dbWizard If the heart rate monitor was turned off, that is probably the culprit. Older Fitbits that didn't have a heart rate monitor used generic sleep graphs and did not have sleep stages. If you turn the heart rate monitor on, you should start seeing proper sleep stages. Hopefully that works for you. Keep me posted.
Best Answer11-30-2022 05:34
11-30-2022 05:34
Turning on the heart rate monitor resolved the problem.
Thanks for the suggestion.
