09-21-2023 19:27
09-21-2023 19:27
My wife has a new Fitbit Charge 5 and has trouble recording the sleep tracking
some nights it will work for an hour or maybe 3 then stop for an hour or 2 and then restart.
the heart rate monitor still records the full time
other times it will not record anything at all and again heart rate records perfectly
then other times it will do the usual problem of recording time but not sleep stages
I have reset the sensitivity to all options and also reset the Charge 5
what else is there other than warranty claim?
09-21-2023
21:54
10:58
ManuFitbit
09-21-2023
21:54
10:58
ManuFitbit
If I understand your issues, I have similar ones: sometimes I get multiple sleep logs, sometimes I get a log without the sleep stages.
For a sleep log that doesn't track sleep stages, note the time you were in bed (start and stop times), then delete the sleep log and then add a sleep log, using the times you have noted.
For multiple sleep logs, delete one, and then edit the other to reflect the total time you were in bed.
09-22-2023 11:03
09-22-2023 11:03
Welcome to the forums @Fred_K.
It's good to see you around @BezierNougat.
Thank you for all the feedback provided regarding the situation with your devices.
When your body is completely at rest and you haven’t moved for about an hour, your device should record that you’re asleep. Before considering other options, please keep in mind that there are some factors that may prevent your tracker from recording your sleep. Please make sure of the following:
If you haven't done so already, please complete a three pulse restart procedure using the charging cable.
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
Best Answer09-22-2023 12:23
09-22-2023 12:23
I have tried all of these suggestions and my new Charge 5 has not recorded my sleep in over a week. This is my 4th Fitbit and I have never had problems with any of my other Fitbits. I also have problems with it recoding my exercise. Both of these sporadically work, it it is always a hassle trying g to fix them.
09-24-2023
18:42
15:39
ManuFitbit
09-24-2023
18:42
15:39
ManuFitbit
That is exactly our problem
have you had a response from fitbit
i have generic try this which we have done to no avail
We have done this numerous times and still no consistent result.
the main reason for purchase was for this function and it does not appear to be fit for purpose so how do we go getting a refund?
09-25-2023 14:10
09-25-2023 14:10
Hello @Fred_K
If you bought the Charge 5 directly from Fitbit, then you should contact Fitbit support for questions about a refund or replacement.
