07-15-2024
07:26
07:27
07-15-2024
07:26
07:27
My Charger 5 is completely unresponsive, and my wife's Charger 5 is experiencing the same issue. We've tried all the recommended solutions, but nothing has worked. This happened right after we returned from an overseas trip. Help!
Best Answer07-15-2024 07:29
07-15-2024 07:29
Hi there, @Ldtran. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 and your wife's have stopped working after your trip. I understand your concern, I will do my best to help you with this!
To better assist you, may I know the symptoms of your Charge 5 devices? Also, I'd like to know all the steps you guys have tried so I can provide something different.
Looking forward to hearing from you.
Best Answer07-15-2024 16:18
07-15-2024 16:18
Best Answer07-16-2024 06:06
07-16-2024 06:06
@Ldtran Thank you so much for getting back and for the details provided in your post.
Regarding the Charge 5 A, it sounds like a battery issue to me. Please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). Since the Charge 5 has been on the charging cable for a day, please see Why isn't my Fitbit device's battery charging?
After trying the above, I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
About the Charge 5 B, it sounds like a screen issue to me. Since it's still syncing, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
07-16-2024 13:50
07-16-2024 13:50
We have done everything you listed multiple times to no avail.
07-18-2024 07:49
07-18-2024 07:49
@Ldtran I'm sorry to hear that the issue persists. Since you guys have tried the steps I recommended here and they didn't work, you have a Charge 5 and report experiencing an unresponsive devices after traveling, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
