04-02-2025
04:03
04:54
04-02-2025
04:03
04:54
Purchase in June 2023, my Fitbit Charge 5 has suddenly stopped working. App shows battery with 63%. The screen is off and I've rebooted several times, the logo did appear briefly as well as a pink circle with a blue x in the middle and apart from that nothing! Any suggestions other than a reboot?
Best Answer04-02-2025 05:01 - edited 04-02-2025 06:07
Hi there, @Sunny.side. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is still not working properly. I understand your concern, I will do my best to help you with this!
In addition to the steps you've done so far, please try the steps below:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the steps above don't work, I'd recommend getting back in touch with our Support Team as I've seen you reach out to them before posting here. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
04-02-2025 05:59 - edited 04-02-2025 06:27
Hi MarreFitbit
Whilst I was waiting a response, I saw previous advice you gave about selecting a different clock via the app, which I did and my Charge 5 is now fully functioning. Thanks.
04-02-2025 06:25
04-02-2025 06:25
