05-05-2024
17:25
02:41
05-05-2024
17:25
02:41
Can’t clear the wallet update notification. Don’t use the pay feature. Also can’t update to clear the notification.
Best Answer05-06-2024 02:46
05-06-2024 02:46
Hi there, @FittyBittyVI. Thanks for stopping by in the Fitbit Community Forums and for the details provided in your post. I will do my best to help you with this!
To better assist you, would you mind sharing with me the exact message you're getting on your Charge 5? Is it stuck on "Set up Wallet"? If so, please note this screen will appear when opening the wallet app on your Fitbit device by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
Best Answer05-06-2024 09:08
05-06-2024 09:08
