09-15-2023
13:40
07:03
09-15-2023
13:40
07:03
All I see is the fitbit icon and nothing else
09-18-2023 07:07
09-18-2023 07:07
Hi there, @jamesyaich. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
Have you tried and checked what @DramaQueenDiva and @Julia_G have shared with you?
If the issue is still happening, please try the following steps in the order listed:
With the steps above, what I want you to do is to pair your Fitbit device first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
09-15-2023 14:07
09-15-2023 14:07
Have you tied the device to your Fitbit account?
one cruise ship at a time!09-15-2023 15:15
09-15-2023 15:15
Hi, @jamesyaich , assuming this is a new issue and you are not seeing a message telling you to download the Fitbit app, or to set up your Fitbit, then it sounds like your Fitbit might have become unresponsive. A restart may help this. Please plug the Fitbit in to charge as normal, and while it is still plugged in and charging press the button on the flat end of the charging cable 3 times pausing for one second between each press. Hopefully this will complete the restart and get your Fitbit back to working normally. You may need to try the restart procedure a couple of times before it works, as it can be difficult to get the rhythm of pressing and pausing just right.
I hope this helps. Let us know how it goes. Welcome to the Community Forums!
09-18-2023 07:07
09-18-2023 07:07
