07-26-2023
09:27
12:38
07-26-2023
09:27
12:38
My charge 5 is stuck on the logo screen. I tried factory reset without success. Also tried reinstalling the app as another site suggested no luck there either. It won't show up when I scan for Bluetooth devices.
Hi there, @JimHisstuck. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Charge 5, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having difficulties to update your Fitbit device, see Why can't I update my Fitbit device?
Hi @JimHisstuck, unfortunately you have been "Bricked" by fitbit like many of us have been with the latest fitbit firmware update. Just read some more posts and you will see...
@MarreFitbit is still in denial about what fitbit has done to their customers.
Best AnswerThey push and firmware update to your device that turned it into a brick. No longer works.
Best AnswerMy advice, after being a loyal customer since 2014 and loving fitbit, is accept that fitbit has gone from a innovative startup with good products and customer service to a large corporate entity (i.e. Google) and you are just one expendable customer to them that they could care less about. It will not get better...
