03-14-2023
02:13
05:49
03-14-2023
02:13
05:49
Having taken it off charge my time is wrong🤷:female_sign:
Best Answer03-14-2023 05:50 - edited 06-03-2023 11:25
Hi there, @Mandysues. Thanks for stopping by in the Community Forums.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for you, try changing your time zone to a completely different one, sync your device, put the correct time and sync again.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
