Best AnswerHi, @Trish3511 did you recently do a factory reset on your Charge 5, or have you recently tried an update that failed (I think those are the usual reasons for seeing a red X on your screen). If you tried a factory reset, then you will need to remove it from your account and try setting it up again, as apparently before doing a factory reset it is important to remove it from your account.
Thanks, I'll try that but it's also not holding its charge. It's giving me a critical battery after being off the charger for a few hours
Best AnswerHello & welcome @Trish3511
Sorry to see you're having issues with your Charge 5.
When I had excessive battery drain, I restarted my Charge 5 multiple times over several days. That seemed to get my Charge 5 "unstuck" and it was back to the battery lasting 6-7 days. I know that you've already done this, but it might take a few more times to get it back to holding a charge.
As for your syncing issues, click here for the Help page that has troubleshooting steps for: Why won't my Fitbit sync? Hopefully, the provided suggestions will work for you.
If none of the troubleshooting steps gets your Charge 5 back to normal operation, I suggest you contact Fitbit support, especially since your device should still be under warranty. When I had a non-responsive screen on my Charge 5, Fitbit support walked me through the same troubleshooting steps I had already tried. When they confirmed that none of the troubleshooting returned my device back to normal operation and that it was still under warranty, they sent me an offer to replace the tracker/pebble or a discount on a different device. I choose the replacement. So far, it's working fine.
It might take a bit to get through to Fitbit support as they have been very busy lately. Click here for: Fitbit support
