03-14-2023
15:07
08:01
DavideFitbit
03-14-2023
15:07
08:01
DavideFitbit
My Charge 5 turned off suddenly today, and won’t turn back on again. I have connected it to the charger and it is now just constantly vibrating (and still not turning on). I have tried resetting it from the plug several times, but it has not worked. What else can I do? It is about a year old.
Moderator edit: format
03-16-2023 08:01
03-16-2023 08:01
Hi, welcome to the Fitbit Community forums, @Lucy19.
I appreciate the information provided about this inconvenience with your Charge 5 and for confirming that you already tried the restart.
In addition to the three pulse restart procedure using the charging cable, please try the following steps in case it's related to the battery or to the display:
05-06-2023 06:46
05-06-2023 06:46
I am having this exact same issue and can’t find a solution. I’ve tried the 3 button reset and it still doesn’t switch on, just continues vibrating.
I’ve tried syncing to my app but the app can’t even find the charge 5 so not sure what else to try.
Thanks
05-11-2023 18:04
05-11-2023 18:04
Mine just started doing this in the last week. Last time it happened, I was able to put it on the charger and it kicked back on but now it's unresponsive. So frustrating.
05-12-2023
10:41
09:25
DavideFitbit
05-12-2023
10:41
09:25
DavideFitbit
Same here. Working fine. Noticed an intermittent vibration. No face/appears dead. But it appears that it did sync when I tried. Put it on charger and vibrated continuously. No life. Opened app and saw an update. Trying to do update now, with phone on charger and fitbit on charger and my device can't find the fitbit - "Looking....." What else should I try. I can't try shutting down because the fitbit is acting dead.
My reply to fitbit's reply -
This is very unimpressive and reflects poorly on Fitbit.
05-15-2023 21:25 - edited 05-15-2023 21:26
Isn’t it weird how a SUBSTANTIAL amount of us are running into the same issue, particularly around May 10 - May 13 timeframe? OR this very specific update that was installed on May 11 (version 1.188.58)
I’m out of warranty so I am out of luck and going through my credit card but this is clearly their fault. See other post:
05-17-2023
03:51
09:26
DavideFitbit
05-17-2023
03:51
09:26
DavideFitbit
Same thing happened to me! Nothing you can do! They will have to send you a new one! Mine wasn't even a year old. I use mine for an alarm and EVERYTHING I depend on these lasting longer
Same!!!!!! I've used a fitbit FOREVER I depend on it for everything!!! They can't even make them work for longer than a year. I had to get mine replaced for the same issue!!! Third time I've had it replaced! Sounds like I need to look elsewhere toooo!!!!
05-17-2023 05:31
05-17-2023 05:31
05-17-2023 07:03
05-17-2023 07:03
Hi Tracy,
We understand your displeasure, but we really do our best to improve our services and also the quality of the products.
There are millions of customers who use them for years and do not report any failure and when it is reported, assistance is provided as we have done in your case and if the mishap persists, the warranty is reviewed, as we have also done with you, the which unfortunately has expired and there is no other option to offer. If there were, we would gladly do so.
If you have any concerns or questions, we kindly ask you to visit Fitbit Support.
Sincerely,
Paula M. and the Fitbit Team
my reply -
I understand that.
05-18-2023 09:41
05-18-2023 09:41
Mine vibrated itself to sleep about a week ago, and has been behaving badly since then. After charging it was able to turn on again, but took forever to finish syncing apps while showing an old date/time. I had to terminate the sync and restart it in order to eventually get the correct time to show. Then when the battery died, I had the same sync issues after charging it up again.
Today it showed an X in a red circle when I tried to check the time, and after trying the pulse reset, it is stuck on a blue logo.
05-19-2023 06:46
05-19-2023 06:46
Same! Sad to say it's junk now!! Hopefully you can get a replacement and IN A TIMELY MANNER!! It's been a joke for me. Shipped Monday was suppose to be here yesterday, but shows it's still sitting there! 😔
05-19-2023 07:20
05-19-2023 07:20
Hello, thanks for your response. Unfortunately this has not worked and the device continues to be unresponsive. Are there any other steps I can take?
05-19-2023
07:30
07:31
DavideFitbit
05-19-2023
07:30
07:31
DavideFitbit
Same here also. Expected delivery was yesterday. Tracking info says it hasn't even started the journey to me.
Yep - buy another one. That's the only option other than ditch Fitbit. At least try to get yourself the 35% discount by calling customer care.
05-19-2023 07:43
05-19-2023 07:43
It’s really frustrating. Seems like they’re built to break as soon as their warranty is up!
05-19-2023 09:57
05-19-2023 09:57
That's what I said to them. Looks like they flipped the switch 2 weeks tooo soon on some of these!!! Absolutely horrible customer service mine says it was shipped Monday the 15th and I should have had my replacement yesterday. Look up tracking and it is still waiting to be picked up! I was told to vontact USPS and I did, but I can't inquire about it since it isn't picked up! Shouldn't someone in shipping realize there are packages sitting there since at least Monday when it's Friday now!!! Thus is unexceptable.
05-20-2023 14:04
05-20-2023 14:04
Today I started to experience the same issue with my Charge 5 as all others on this thread and haven't found a way to fix. During my software developer career, I spent part of the time (17 years) supporting upgrades for major products. This experience has led me to sense when a problem can be tied to an upgrade, and in this case it certainly feels like it is, based on comments on this thread and elsewhere. Fitbit support, please own up to this problem and help out your community.
06-07-2023 20:32
06-07-2023 20:32
Mine is now doing this too. Literally vibrating itself to death. Not even a full year old. It's ridiculous and extremely disappointing.
06-13-2023 14:39 - edited 06-13-2023 14:40
Mine started doing this right in the middle of a swim today. From what I can tell, I had taken a break after my first set, finishing the tracking (I miss being able to pause like I could on the Charge 3, even if that was technically cheating) and starting a new session for my second set. I initially noticed something was wrong when I tried to flick my wrist underwater to check my time like I normally do, but nothing would come up on the screen. After I finished and exited the pool, I found the Fitbit to be completely unresponsive, but randomly vibrating. Oddly, it did still sync to my phone at least, but it tracked none of my second set. It did seem to be tracking steps and such for the time it was misbehaving. As soon as I got home I fiddled with the charger, and thankfully I was able to get the unit to reset. I'm just not confident that it's not going to happen again in the future. I'm quite tempted to ask for a warranty replacement now rather than once it falls out of warranty.
I had noticed the first month I owned it (November of last year) that one day it randomly went from around a 60ish percent charge to completely dead within an hour while I was at work. I was quite set to bring it right back to Best Buy and return it, but gave it a second chance and it had performed relatively without fault until today.
Edit: I had to edit my post before posting it due to content supposedly not allowed in this community. What in the heck is wrong with "sixty hyphen seventy" written in the numerical form? It was in reference to the charge remaining in my second paragraph.
06-26-2023 01:02
06-26-2023 01:02
Mine started doing this last Thursday. I let the battery run out, as soon as I charge it, it starts nonstop vibrating. The funny thing is, the Fitbit app is recording huge amounts of steps still, even though I'm traveling and haven't even been close to the Charge 5 these days. Nothing else is syncing since Thursday though..
I'm in the EU and we have 24 month warranty, so I'm not too worried about getting a new one since my device is less than 2 years old.
LIMITED PRODUCT WARRANTY FOR NEW PRODUCTS
Fitbit warrants to the original purchaser that your Fitbit-branded device and accessories that are new (the "New Product(s)") shall be free from defects in materials and workmanship under normal use for a period of one (1) year from the date of purchase, except that if you reside in the European Economic Area (EEA) and you purchased your Fitbit product in the EEA, the warranty period is two (2) years from the date of purchase (the "New Product Warranty Period").
07-11-2023 01:00
07-11-2023 01:00
This happened to me yesterday and I followed all the steps but nothing works. I'm so sick of fitbit, it's not the first time I'm having issues and their customers service is appalling. Never have I experienced more lack of care for customer satisfaction. This is the last chance, then I'm switching to a better brand!
