01-10-2024
12:23
12:33
ManuFitbit
01-10-2024
12:23
12:33
ManuFitbit
My charge 5 won't turn on, charge or sync. I plugged it in, pressed the button on the charger 3 times one second each time. It won't show the reset symbol but it does vibrate when I hit the button.
I bought a replacement charger with the same result. Any help would be appreciated.
Best Answer01-10-2024 12:39 - edited 01-10-2024 12:51
Welcome to the forums @E_underfoot.
Thank you for sharing the inquiry regarding your Charge 5 and the attempt to solve it on your own. Sorry to know about the difficulty.
If this is related to the battery, please make sure that you've followed the steps provided in this article: Why isn't my Fitbit device's battery charging?
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure described here: How do I restart my Fitbit device?
12:45
09:18
ManuFitbit
01-10-2024
12:45
09:18
ManuFitbit
Thank you for replying. I have tried all of these in the last few weeks. I got a new charging cable in case that was the issue. But my charge 5 screen is black and unresponsive.
Are there any other suggestions?
Best Answer01-11-2024 10:05
01-11-2024 10:05
@E_underfoot welcome back to the community.
Thank you for the response and for letting me know that you already tried the steps suggested.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Please keep an eye on your inbox and spam folder.
Best Answer01-11-2024 11:06
01-11-2024 11:06
Hi I have the exact same problem with my Charge 5 and have done all of the same steps with no solution
Best Answer01-11-2024 14:51
01-11-2024 14:51
exactly same problem that I had starting few days ago. when it still had charge, it drained so quickly within just a few hours. once it's completely drained, I haven't seen it turning on or even charging with I thought was a perfectly working charging cable. why fitbit o why?!
