11-17-2024
23:18
04:16
11-17-2024
23:18
04:16
My FitBit 5 won't charge, I have tried the steps on this forum by pressing the button on the charge cable three times, however it is still not working.
Best Answer11-18-2024 04:27
11-18-2024 04:27
Hi there, @Tambaino. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Charge 5 is not charging. I understand your concern, I will do my best to help you with this!
Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Charge 5 on the wall socket, try using another CE certified USB adapter for low energy devices.
If you haven't done so yet, I'd recommend following the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
Best Answer11-18-2024 09:40
11-18-2024 09:40
Best Answer11-18-2024 09:59
11-18-2024 09:59
@Tambaino Thanks for the update and for trying the steps I recommended. Since all the steps you tried didn't work, you have a Charge 5 and report it's not charging, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done. Click here to get access to it.
