06-05-2023
03:50
04:52
06-05-2023
03:50
04:52
06-05-2023 03:58
06-05-2023 03:58
Hi, @Skumble91, welcome to the community, you can reach "Customer Support" via the chat facility or phone for prompt attention. FYG this is a dynamic link & should provide you with your local contact details. It's a good move to make a note of the steps you have taken and the results so you can brief the agent clearly. You should check Fitbit's warranty as you appear to be outside Amazon's returns period. Inevitably this will rely on Indian consumer law.
I hope this helps.
Cheers
Gr4ndp4 | UK
06-05-2023 04:03
06-05-2023 04:03
You should try to contact customer support by using the link on the Fitbit website. If they give you the option to return the product for a refund, I suggest you take the refund rather than get a replacement. Based on the enormous number of posts about this type of problem, your experience is not unusual for a Charge 5.
06-05-2023 04:57
06-05-2023 04:57
Hi there, @Skumble91. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 5. @Surfista @Gr4ndp4 Thank you so much for your help and advice!
I've seen you contacted our Support Team after posting here via email. Please stay tuned to your inbox, someone will reach out to you shortly.
In the meantime, please try restarting your Charge 5 by following the steps below:
06-05-2023 11:46
06-05-2023 11:46
Hi,
I tried this option but still not holding the charge. It is charging fully but getting discharged within 10 mins
06-05-2023 12:51
06-05-2023 12:51
Please see my comment above. The sooner you contact customer support, the more likely it is that they will be able to replace your device or provide a refund.
06-06-2023 04:33
06-06-2023 04:33
@Skumble91 Thanks for the update.
I've seen our Support Team has already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
@Surfista Thanks for your advice!
